torque arm/trans hits floor
Old Sep 17, 2010 | 11:19 PM
mustangkiller71's Avatar
mite have been talked about b4 but when im on the gas & my trans shifts hard... it sounds/feels like the tail end of my trans is goin 2 come up thru my floor. the rubber torque arm bushing is new and tightened down & my trans is tightened down 2 the crossmember wth a new rubber trans mount, so why is it hiting the floor? any ideas? thnx.
Old Sep 17, 2010 | 11:25 PM
Re: torque arm/trans hits floor
i 4got 2 say its a new rebuilt 700r4, and im running a holley carb so my trans aint shifting from the computer telling it when 2. ive bypassed the computer compleetley.
Old Sep 18, 2010 | 12:18 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I know you said it's a new Rubber trans mount, but it possibly couldn't handle the extra hard shifts. Check the mount again, you may have to go to a poly mount.
Old Sep 18, 2010 | 12:27 AM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
I've had the same problem after I've done some tuning up (more torque caused it?) its only my 1-2 shift after that its fine I'd like to know if you figure something out
Old Sep 18, 2010 | 12:40 AM
thnx guys. ill look @ the mounts agian 2moro. ya its a hopped up 350. not the old wimpy 305.
Old Sep 18, 2010 | 01:05 AM
red rock's Avatar
Car: 1987 iroc
If they check out, I would check your motor mounts too.
Old Sep 18, 2010 | 05:13 PM
when i put my trans in i 4got that i still needed 1 of the 2 bushings in the crossmember. my trans mount is good & one of the 2 in the crossmember is good but the other is trash igot distracted & 4got & jst threw it 2gether. i hope putting a new one in will fix my prob. thnx again guys
Old Sep 18, 2010 | 06:34 PM
red rock's Avatar
Car: 1987 iroc
Glad you found it!
wigmobile
Feb 26, 2025 02:56 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Ragtop Man
Sep 12, 2015 12:23 AM
