pros and cons on a tko 600
Old Sep 20, 2010 | 12:07 AM
ryguy1989's Avatar
Car: 1989 pontiac firebird formula 350
Engine: 350 stock but not for long
Transmission: 700r4 but swap to manual
need to know form people that actually put the trans in there 3rd gen car thanks.
hard shift
size of trans
streetability
Old Sep 20, 2010 | 04:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: pros and cons on a tko 600
trans has a notchy shift, but its a very positive feel, no guessing if you are in gear, and no sloppy shifts. Its just fine IMO.
size, its a little tall for the tunnel, it fits, but sits at a decent angle downard towards the rear of the car. I just finished "fixing" this issue, havent driven it since, still waiting on carpet.
streetability, no problem at all. I would have no problem DD's a car with the trans.
in reality though, unless you get a screaming deal on a second hand one, which are hard to find, a lt1 style t56 would be cheaper.
Old Sep 20, 2010 | 10:32 PM
ryguy1989's Avatar
thanks for the reply i was wondering what you had to fix did you fab the floor pan tunnel or what did you do
Old Sep 21, 2010 | 06:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i cut the tunnel from behind the shifter to the first rib, under the radio pod, and up to the top of the tunnel, but not all the way through. I then raised the rear up about 1", and patched the sides of the tunnel back up. Let me raise the back of the trans just over 1/2"-5/8" at the trans mount
I "think" the console wills till fit, but i wont know until I get the interior back together
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
3.8TransAM
Sep 17, 2015 02:16 PM
scotrans am
Sep 5, 2015 04:26 AM
