Transmission acting up
Car: 1992 Camaro RS
Engine: 305 TBI Injection,Edelbrock intake,
Axle/Gears: 89 Trans-Am 3.42
I have a 92 Camaro with an automatic transmission -overdrive,when it shifts up through the gears ,its fine,but say im in 1st,take off is great ,but when I let off the gas ,its like I,m in neutral,it does it in 2nd,and drive.If I were to drop it into 2nd ,say going down a hill,its the same as neutral,this just started,is it ok to drive for awhile or is this major till its fixed?,plz help
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Transmission acting up
Check fluid, is it burnt? The longer you drive like that the worse it may become? How many miles on car? If it were me I'd change the fluid and filter immediately...
The problem is in the overrun clutch. The transmission will have to come out to get this fixed. The clutches could be burned or the sprag itself is gone or the overrun hub is broke. You will know once it is taken apart.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
