Will a 9 bolt survive the LS1?
Old Sep 5, 2010 | 07:43 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Swapping a 2000 LS1 this winter... I have a borg warner 9 bolt 3.08:1 lsd from an 85 camaro in my 91 z28 vert... I will have the 4L60E. Will it handle the ls1? I saw Bluzees video last week with the ten bolt destruction and now im concerned for my own rear end... Searched.
Old Sep 5, 2010 | 08:00 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Will a 9 bolt survive the LS1?
should hold up just fine. 9bolt is a tad stronger than the 10bolt, and you have an auto which reduces shock load to the rear end.
Old Sep 6, 2010 | 07:17 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
9 & 10-Bolts will hold up to stock power until you do something
DUMB & STUPID.
Old Sep 10, 2010 | 10:25 AM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Great to hear! That is one of my main concerns with my build.
Old Sep 10, 2010 | 12:26 PM
skinny z's Avatar
Broke the pinion teeth on my (100 000 mile) 9 bolt on my 1st ever 12 second pass. It had previously survived about a 100 13 second runs before that.
Old Sep 11, 2010 | 02:00 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have one of these but a 10 bolt.Here's a link that will explain how it helps.
http://www.shop.speedunlimited.com/p...gm-9-bolt.aspx
Old Sep 11, 2010 | 03:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
good condition should hold but you never know. I've been 9's at over 140 with 800+ hp on my stock 10 bolt but broke my 9 bolt BW rear on a high 13 second pass with a 1.7x 60 foot with my bolt on TPI L98 I've been 1.41, 1.45, and 1.49 with many many 1.5's 60's on the 4th gen 10 bolt.
Old Sep 11, 2010 | 01:01 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
On street tires you should be fine. HP doesn't break parts, traction does.
Old Sep 11, 2010 | 09:17 PM
Pro Built Automatics's Avatar
If you want it to last, add a steel cap to the ring gear side, reset the backlash to the minimum, use oem posi fluid, and use Lubrication Engineers rear end oil. Add magnets where possible. DO NOT make the transmission shift too firm at any throttle opening. That will help with rear end gear life.
Old Sep 18, 2010 | 08:20 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
where does one get this steel cap for a nine bolt
Old Sep 18, 2010 | 11:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Seeing as you will be running an automatic transmission I see no problems. If you don't have a TA rear cover I would recommend that you get one to add a little strength.
Old Sep 19, 2010 | 03:48 AM
I know there is not much for a nine bolt, but try the different rear end builders to see if one is available.
Old Sep 19, 2010 | 10:07 AM
skinny z's Avatar
Hawks has one for sale. (At least it was)
http://www.hawksthirdgenparts.com/ca...entgasket.aspx
Old Sep 19, 2010 | 01:38 PM
Car: 1989 GTA
Engine: 369 TPI
Skinny Z has posted a link to the one I bought. I also bought the stud kit.
With my new motor it just over powers the tires in 2nd gear and forget 1st gear. I had KevinZ28 tune my new motor for driveability yesterday and will wait for the dyno to tune the WOT portion. Just useless and dangerous to try and do it on the city streets. By the way Kevin did a real good job. Hard to believe that the motor idles this nicely at 775rpm. This car could easily be a daily driver as it has the A/C, cruise control and all the creature comforts that it came with from the factory.
Old Sep 19, 2010 | 01:50 PM
skinny z's Avatar
Nice.
Old Sep 21, 2010 | 09:54 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Would there be any concern for the axleshafts? Is replacing them with Moly 'shafts recommended? Does anyone know of axleshafts for the BW nine bolt?
Old Sep 21, 2010 | 09:56 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
yes
Old Sep 21, 2010 | 10:16 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Originally Posted by 92FBirdVert
yes
um... ok care to elaborate?
Old Sep 22, 2010 | 07:29 AM
Engine: 5.0 TBI
My brother has a stock 9 bolt under his 2001 camaro ss thats supercharged and he hasn't had any trouble with it. Dynoed around 425 rwhp. Not sure what your doing exactly DD or Drag racing.
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
