Please Help...
Old Sep 26, 2010 | 01:12 AM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Please Help...
My drivers side axle came loose/out while making a turn. WTF???? The drivers side axle is super loose, comes right out. Passanger's side has some play and the Diff makes noise when I turn the passanger's side axle. Literally I was driving and when the car stopped moving, the axle was about four inches out. What does this mean??? 1990 Trans Am, 305 TPI. Not sure what Kind of Diff, But I LITE both of my tires up... Or at least I did... Oh How Sad.
Old Sep 26, 2010 | 01:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Please Help...
Broken C clips?
Old Sep 26, 2010 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Please Help...
It means you should do some serious investigating before you drive the car again. The following may be helpful:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Sep 27, 2010 | 08:59 PM
Re: Please Help...
Okay, so I open up the Diff Cover and Viola!!! A C-Clip. I put in a Open Diff/Rear End (Entire Rear End) I aqquired. This is so I can continue to drive the car for the mean time. Now I would like some information on to why this happend? What should I do? I would really like to fix it, as I'm not a Fan of The Peg Legged Burn-Out!!!
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
