transmission mount
Old Oct 8, 2010 | 01:34 AM
jll87TA's Avatar
Car: 87 trans am, 82 trans am
Axle/Gears: stock
transmission mount
I have an 87 trans am with the 700r4 transmission, when I speed up something hits the car I'm guessing the transmission mount is broken. Is it hard to replace the transmission mount? What do I have to do? Thanks
Old Oct 8, 2010 | 02:19 AM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: transmission mount
It's very easy to do put the car up on ramps or jack stands support the transmission with a jack. Unbolt the trans crossmember and trans mount replace and bolt everything back in its only 6 bolts and 1 nut.
Old Oct 8, 2010 | 06:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/trannymount
If you're considering poly, check the following link:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Old Oct 8, 2010 | 11:51 AM
Rajin's Avatar
Car: 1974 Camaro Z28 Type LT
Engine: 350 sbc
Transmission: Borg Warner T5
I had a similar issue with mine. Turns out it was the torque arm bushing that had broken. It's attached to the side of the transmission. It was hitting the tunnel everytime there was a change in speed.
Old Oct 8, 2010 | 12:28 PM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
that would be my guess too mine is worn but not terrible you only hear the thud when i take off from a stop
Old Oct 8, 2010 | 12:46 PM
JamesC's Avatar
A broken torque arm mount isn't unheard of by any means, but the trans mount is far more often the culprit. You'll be under the car, so checking both won't be an inconvenience.
JamesC
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
