How to swap to a t56 from a 700r4 how to? Anyone done a write up?
Old Oct 12, 2010 | 09:51 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
What all is needed? And how to do it
I know you need a t56 from a lt1 car. Flywheel etc
What hydro setup will work? What crossmember will work? Do you need third gen or 4 gen pedals?
Old Oct 12, 2010 | 09:54 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: How to swap to a t56 from a 700r4 how to? Anyone done a write up?
Its the second link at the very top of this section..
https://www.thirdgen.org/forums/tran...ap-thread.html
Old Oct 12, 2010 | 10:02 AM
Axle/Gears: G92
Thanks for some reason my phone doesn't load the sticky threads.
Old Oct 12, 2010 | 10:14 AM
Axle/Gears: G92
I didn't see it in that thread but who sells a kit to make the stock speedo work?
Old Oct 12, 2010 | 03:30 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There's an electronic ratio adapter (see the sticky speedo gears thread for a link to transmission center.com) which would work to change the 17 pulse / driveline revolution signal to 4000 pulse / mile signal that your car has stock.
Dakota Digital has an SGI-5(?) box which would work too.
Old Oct 14, 2010 | 05:40 PM
Axle/Gears: G92
Ok thanks for the info
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
