Transmission interchange
Old Oct 13, 2010 | 12:19 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
First I have a 1989 Firebird Formula with 5.7l,
I have a transmission that is out and will not go into reverse. I looked at rebuilt or rebuilding it but have seen in my area on Craigslist 700r4 for sale that are rebuilt and cheaper.
I need to know what transmissions will be interchangeable with this such as Chevy trucks or years.
Old Oct 13, 2010 | 12:42 PM
Drew's Avatar
Re: Transmission interchange
Unless the transmission is out of a Camaro or Firebird it's not going to have the mounts for the torque arm. Sometimes you can get away with changing the tailshaft, but it's not really worth it. With exception of the Corvette, most other cars that had the 700R4 had a softer version. Your current transmission is a better choice for your car, just shop around and have a good shop rebuild it.
Old Oct 13, 2010 | 12:44 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Your trans. mount is behind the pan on the main case.
Your torque arm mount is on the tailhousing.
Most any third gen, car or truck 700-R4 trans. (pre-93 trucks, pre-94 cars) will work and accept the TCC wiring plug.
You'll need to use the right dipstick tube and the thirdgen tailhousing. Keep your '89 VSS and speedo gears off the old trans. to use also.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 20, 2015 09:31 AM
sbrandon
Sep 9, 2015 07:31 AM
greenyone
Sep 2, 2015 03:39 PM
