Tranny Slips
Old Oct 17, 2010 | 10:25 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
Tranny Slips
From what I can tell it is my transmission slipping.
Symptoms:
1. Jerking when accelerating and cruising (more noticeable accelerating)
2. When attempting to accelerate at a decent speed (not pedal to the floor) the rpms go to about 3.5k and the car barely accelerates then catches and goes.
3. Today I was taking some S Curves around my home town and going 55-60 with the pedal down just enough to stay at a constant speed the transmission would shift down while taking a left turn on the S Curve and when I got to the right turn it drove normal. I went on different S Curves. Ones that started going left and one that started right.
Extra Info:
I am told by the previous owner that the car has a shift kit. Don't know if that makes a difference.
Last I knew the fluid level is normal.
Also, I am going to only have it running for maybe two or three more weeks and then it's going into hibernation for the winter.
I need to know what's going on and what I can do. Please help me out!
Old Oct 18, 2010 | 08:56 PM
Shane4524's Avatar
Re: Tranny Slips
Someone has to know something...
Old Oct 20, 2010 | 09:04 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Re: Tranny Slips
Check your trans fluid, engine running, hot and on level ground. If ok, check for a code...you might have a TCC solenoid issue. Smell the fluid. if it smells burned, you're probably slipping. You can tell by dropping the trans pan and wipping your finger across the bottom of the pan...you'll have lots of filings if you've slipped.
Old Oct 20, 2010 | 09:22 PM
Shane4524's Avatar
Re: Tranny Slips
If the fluid level is too high I am told that it can cause issues. How would I remove fluid if I do have too much?
If I drop the trans pan wouldn't that lose all the tranny fluid....?
Old Oct 20, 2010 | 09:29 PM
Sandslot's Avatar
Engine: LB9
Re: Tranny Slips
Too much trans fluid will blow the clutch pack o rings....it is actually better to be a little under than over. I have used the "oil boy"...it is a suction pump with a long tube that goes into the dipstick & into the pan. You can pick up one of these about anywhere.
If you pull the pan, you'll lose about 6 qt, but not all (total appx 9 if I remember)
Old Oct 20, 2010 | 09:45 PM
Shane4524's Avatar
Re: Tranny Slips
Alright. Well it probably could use to get rid of a bunch of fluid and get new stuff.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
camaronils
Sep 20, 2015 02:57 PM
IROCZ1989
Sep 4, 2015 11:54 AM
