t-5 speedo sleeve question
Guest
Posts: n/a
I have a 68 Chevy truck that I put a T-5 in from I believe an 83 Camaro. I noticed it was leaking around the speedometer cable, so I found out from here that I need a new sleeve. I ordered one the other day, PN345215, and when I went to put it in tonight, I noticed it was different from my original on, which looks this.
Does anyone have a part number for that sleeve, or did it come in anything else besides T-5s? Also, I need the connector plug thing for the reverse lights. Does anyone know where to get that because GM discontinued it. Thanks in advance.
Car: `86 SS / `87 SS
Re: t-5 speedo sleeve question
Napa carries replacement seals or o-rings which install into speedo gear sleeves (small ones the gear slides into.) There's a chance you could service your sleeve with those. You won't easily find a new one like yours. Why don't you use the 345215?
The reverse lights plug is a 2 prong weatherpak; easy to find at any parts store. You can use a micro-screwdriver to remove the contacts from the plastic housing and just use the new housing on your old wires if you don't want to splice.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following (give it a moment to load) for the TH350, T-5 and Super T-10:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
JamesC
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
james c directed me to that website too,, i bought a replacement t5 housing with seals for like $9 plus shipping...it doesn't look like the original you have there....but it fit and i have added atf oil in it and so far it looks like no leaks!....thankyou..and good luck...
ambainb
Apr 25, 2016 09:21 PM
