Camero tranny Help???
Old Oct 23, 2010 | 07:59 PM
corey67114's Avatar
I put an 01 Camero trans in behind my small block and it worked perfectly for 2 years. removed to finish car. After reassembly, I can't shift into gear when engine is running. Its like I'm not moving the TO bearing far enough. I used spacers to move the hydrolic piston as far as I could, without change, so back to square one. I saw mention of TO bearing being installed backwards, and my neighbor thought the clutch disc might be stuck to the pressure plate or the clutch cage, and suggested trying to force it loose with a good pop of the clutch, or slamming on the brakes after spinning it up on jacks (not big on this idea) Any help please?
Old Oct 23, 2010 | 08:06 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Re: Camero tranny Help???
Might be simpliest to just pop the box out & take a look....
Old Oct 25, 2010 | 03:17 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
You should be banned for not know how to spell
CAMARO
Old Oct 25, 2010 | 04:50 PM
Rajin's Avatar
Car: 1974 Camaro Z28 Type LT
Engine: 350 sbc
Transmission: Borg Warner T5
How long was the transmission out? The clutch disc could be stuck to the flywheel.
If that's the case, throw the rear end up on jack stands, step on the clutch pedal, and crank the engine over a couple times. That might be enough to break it loose.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
