lost posi?
Old Oct 24, 2010 | 12:24 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
lost posi?
So my car has always been posi and left 2 dark tire makes when launching hard. The other day I notices it was just laying down rubber from my passenger tire. My friend seems to think this happened because I didnt add the posi additive when I changed the gear fluid last time and I'll be ok after I correct that. Any ideas???
Old Oct 24, 2010 | 12:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: lost posi?
I wouldn't be surprised. Throw the GM additive in and see what happens--you only have the cost of the bottle to lose.
JamesC
Old Oct 24, 2010 | 03:56 PM
Drew's Avatar
Re: lost posi?
The purpose of the limited slip additive is to smooth out the engage/disengage of the clutches... Leaving it out isn't going to keep the clutches from grabbing, but it might make them wear faster. Adding the additive now isn't going to fix any damage that's been done, and it's not going to magically bring back the limited slip. Don't waste your time and money on additive at this point, start saving for a new carrier.
Old Oct 24, 2010 | 04:55 PM
JamesC's Avatar
Re: lost posi?
Just for the sake of more info. Any popping/jerking from the rear on a turn?
JamesC
Old Oct 24, 2010 | 05:24 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: lost posi?
are u sure you car isnt a 9bolt? no clutches just cones. they wear fast
Old Oct 24, 2010 | 06:17 PM
Car: 89 Formula 350
Re: lost posi?
it is a 9 bolt
Old Oct 24, 2010 | 08:26 PM
Engine: ls1, LB9
Re: lost posi?
it is a 9 bolt
e
then im sure your cones are bottomed I would take it easy on the rear until you can
A, buy new cones
B, machine your cones and shim the side gears
C, buy a working posi
right now your side gears are not putting any preload on the spider gears and the extra backlash will wear them out/ break fast
I helped write up a repair for these years ago it was a sticky
Old Oct 24, 2010 | 08:35 PM
JamesC's Avatar
Re: lost posi?
There may be info in the following link, TPI, that will be interesting.
https://www.thirdgen.org/forums/faq-...now-about.html
88, is there some disagreement on whether the 9-bolt limited slip requires the additive?
JamesC
Old Oct 24, 2010 | 09:12 PM
Engine: ls1, LB9
Re: lost posi?
JamesC
yes, and to be honest ive changed my mind a few times i dont think its needed as of now. I figure its a clutchless posi so there should be no chatter
oh and that link u had shows mine with each page posted by me and duck
https://www.thirdgen.org/techbb2/sho...ighlight=9bolt
Old Oct 24, 2010 | 11:10 PM
big gear head's Avatar
Re: lost posi?
Most cone type differentials require at least one bottle of additive. The Auburn usually requires 2 bottles. Adding the additive now will not help at all with the OP. Yours is worn out and must be repaired.
KO1
16
Oct 15, 2015 05:00 PM
3.8TransAM
Sep 27, 2015 08:37 PM
