Drive/Driven Gears on Turbo 350 Swap? Help!
Old Oct 28, 2010 | 12:43 PM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
Hey guys,
I am getting close to installing my freshly rebuilt 1974 Turbo 350 into my 82 Trans Am and I need a little help. I am a little unsure as to which drive/driven gears I need for it. First, here's some stats:
1982 Trans Am, 2.93 rear axle (RPO GU3).
Tires: 215/65/R15
Now, I've tried using the Speedo calculator here:
http://www.tciauto.com/Products/Tech...eedo_gears.asp
The tire diameter calculates to 26.00 in. The drive gear on the th350 appears to be 7 teeth (pink). Entering all that info into the calculator says I need a driven gear of 15.89. However, the TH350 gear chart below only starts at 18 teeth??? I am quite confused. Do I need to replace both drive and driven gears and if so, which ones should I get?
Thanks in advance!
Joe
Old Oct 28, 2010 | 08:30 PM
Re: Drive/Driven Gears on Turbo 350 Swap? Help!
http://www.transmissioncenter.net/sp...____va.htm#350
bellez77
Sep 5, 2015 08:39 PM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
