T56 vss
Old Oct 30, 2010 | 05:32 AM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
T56 vss
Ive had my t56 in my car for a few months and Im curious about the speedometer. Im aware I need a dakota digital box, but what would happen if I just hook the the speedometer straight to the t56? Will it read under or over the actual speed? Im just curious.
Also is there an alternative to the dakota digital box? Something DIY maybe?
Old Oct 30, 2010 | 08:34 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 vss
What type of vehicles are we talking about? Most thirdgen's used mechanical speedos with the VSS buffer in the back, supplying the signal to the ECM. The T56 VSS has a different PPM and waveform than the thirdgen VSS buffered signal.
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
If you have a late-model thirdgen with the electronic speedo, you're in better luck, but still have some tweaks to do for the PPM.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
