Mileage out of 700R4/4L60E?
Old Nov 7, 2010 | 11:13 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I'm just curious as to the highest miles these transmissions see.
I just came across a '94 4L60E with over 314K original miles in a farm truck turned almost daily driver. Owner said it was used to pull just about anything.
Started slipping going into 2nd.
What I think happened was that the 1-2 accumulator wore out and burned the 2-4 band and tore up the reverse input drum. Aside from that it was still driving with piston seals that cracked when removed.
Old Nov 11, 2010 | 10:08 PM
TZFBird's Avatar
Engine: 327
Re: Mileage out of 700R4/4L60E?
Just so everyone is aware. If you purchase a "used" reverse input drum, they just turn it down so it's smooth again. I got one and it's just been smoothed. I have to send the old one back as a core. Had I known, I would have taken it to work and had a machinist do it.
It's back together and we'll see how it turns out. Overall I think I've found a new appreciation for these transmissions. I think I could start a preventative maintenance build sheet after doing this one.
Replace all accumulator pistons every 150K miles and it should last forever if fluids are changed regularly.
plm99
Southern California Area
Nov 16, 2015 05:21 PM
sammy52401
Nov 11, 2015 07:20 PM
bjpotter
Oct 15, 2015 11:07 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
Dragonsys
Sep 25, 2015 03:51 PM
