Limited Slip Differential for 700-R4
Old Nov 9, 2010 | 09:24 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Hey, I plan on geting limited slip differential for my one wheel wonder firebird. I was wondering how do i find the right differential? I dont know where to start...ANY help is needed!@ THANKS
Old Nov 9, 2010 | 09:29 PM
big gear head's Avatar
Re: Limited Slip Differential for 700-R4
For street/strip use I only recommend 2, the Eaton Posi and the Duragrip. These are almost exactly the same except for the clutch material and the price. For road racing or auto cross the Torsen might work a little smoother. What gear ratio do you have?
Old Nov 9, 2010 | 09:58 PM
hairysox33's Avatar
His sig says 3.23
Old Nov 9, 2010 | 10:04 PM
92Firebug's Avatar
Engine: 305 TBI
Originally Posted by hairysox33
His sig says 3.23
lol yup 3 23 gears all the way haha
Old Nov 9, 2010 | 10:07 PM
92Firebug's Avatar
Engine: 305 TBI
would this work? http://www.summitracing.com/parts/ETN-19557-010/
Old Nov 9, 2010 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, that's for an 8.5" 10 bolt.
Old Nov 9, 2010 | 10:13 PM
92Firebug's Avatar
Engine: 305 TBI
what will work? i have a junkyard rearend/differential...
Old Nov 9, 2010 | 10:57 PM
There is an Eaton Posi and a Duragrip for the 7.5 rear end that you have. They are made with 26 and 28 splines to fit whatever axles you have. They are only made in 3 series, which will work just fine with your 3.23 gears.
Old Nov 10, 2010 | 12:11 AM
92Firebug's Avatar
Engine: 305 TBI
ok thanks
Old Nov 10, 2010 | 11:10 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I saw a thread about the PowerTrax(?) no-slip device that can be added to the existing diff. Is that any good? Cheap? Easy?
Old Nov 10, 2010 | 11:23 AM
Yea, it's easier to install and it's slightly cheaper. They usually pop and jerk slightly when turning corners, but not too bad. The Eaton and Duragrip are smoother.
Old Nov 10, 2010 | 12:31 PM
92Firebug's Avatar
Engine: 305 TBI
i dont care about price or install...i just want a good smooth performing differential that stops me from being a one wheel wonder
Old Nov 10, 2010 | 05:41 PM
http://www.nastyz28.com/forum/showth...t=install+posi
Read this and see if you feel able to do it yourself.
Old Nov 10, 2010 | 11:07 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You can do what I did and go with the Eaton posi. and LPW Ultimate support cover. Here's the link to the Eaton unit at Jegs Performance = http://www.jegs.com/webapp/wcs/store...archTerm=19599
And here's a link to the cover = http://www.jegs.com/i/LPW/619/301-7....oductId=744455
Heres a link to Eaton explaining how there posi. unit works = http://www.eaton.com/EatonCom/Produc...tials/PosiLSD/
Old Nov 11, 2010 | 09:13 AM
92Firebug's Avatar
Engine: 305 TBI
WOW That Was SOOO Helpful Thank You so much! Is it hard to install?
Old Nov 11, 2010 | 09:52 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
The install for a first timer can be very frustrating, but technically it's not really that hard if you have the right tools. Stuff just doesn't drop in and go; you need to check, measure, check, measure a few times. It's all about that contact pattern and the preload. If it's off by a few thousandths, it will make noise. Trust me, you don't want the noise.
If you wanna do it right, you will need spend some money on tools. You can improvise, however, you have to be careful.
Old Nov 11, 2010 | 12:34 PM
92Firebug's Avatar
Engine: 305 TBI
I was thinking about just taking it to a shop to have it installed.
Old Nov 11, 2010 | 11:40 PM
Good man! You just saved yourself a lot of time and headache.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
