I need a Stock T56 output shaft and tail housing
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
I'm in need of a stock T-56 output shaft and tailhousing. It's a 2000 Camaro. The snap ring came off the reverse synchro and things went downhill from there. Good used parts are what I'm looking for since it's for a friend.......
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: I need a Stock T56 output shaft and tail housing
D&D use to list $99 take-out shafts, but I don't see them on the web site any longer.. You might have to call to see if any are available.
http://www.ddperformance.com/shop/in...th=110_103_115
Most tremec/T56 shops would also be places to check. (Tick, TDP, thegearbox, rsgear, RPM, etc.)
The tail housing might be harder to source used, but the same places would be the best bet other than eBay, craigslist, etc if you want to take your chances..
I believe thegearbox.org will sell you a new tail for right around $180...
Car: 89 Z28
cool. Tx for the info..... let the hunt begin......
I have a few new take outs. I can do $100 for a 27 spline shaft. I will check for a tail if you want one. Thanks Bob www.hanlonmotorsports.com 610.469.2695
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
billy, camaro, housing, output, rear, replacement, shaft, shawver, spline, t56, tail, tailhousing, tailhousings, transmission, tremec
