Loud road noise at 70+ MPH
Subscribe
Nov 13, 2010 | 07:39 PM
I have a "road noise" that gets pretty loud as soon as I hit 70MPH. Kinda sounds like driving a truck with knobby tires. I can feel the high frequency vibration in the floorboard. It sounds like it comes from the front.
I just put on new tires so that's not the issue.
Just had an alignment so that's not it.
I blocked up the rear and went 80MPH and it didnt make the noise so I'm ruling out the driveshaft.
What else should I check, wheel bearings?
Reply 0
Nov 13, 2010 | 07:42 PM
Re: Loud road noise at 70+ MPH
if it bearings it will sound like a low pitch throbbing noise and if you jack up the front end (tires off ground) and wiggle the tire you will feel an excessive amount of play or wiggle.
Reply 0
Nov 13, 2010 | 07:44 PM
Check your wheel bearings. Bad universal joints will make noise and couse vibrations too.
Reply 0
Subscribe
