700r4 shift okay at WOT but have to take foot off pedal to shift??
Old Nov 16, 2010 | 08:13 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Just as the title says. Normal 700r4 with a shift kit I believe. I remember first driving it when I got it and it shifted okay. I had a leak that I later found out was coming from my TV cable seal, and fixed that. Would a low fluid level do this? Like I said WOT it shifts fine but when cruising at regular speeds I have to take my foot off the pedal then it shifts.
Old Nov 17, 2010 | 12:33 AM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
Re: 700r4 shift okay at WOT but have to take foot off pedal to shift??
Sounds like the TV cable is out of adjustment.
Old Nov 17, 2010 | 12:43 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
sry dont mean to steal ur thread but i have a similar question.. what if it shifts fine while regular driving but when u go WOT u have to let off the gas for it to shift?
Old Nov 17, 2010 | 08:59 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I over-fill my trans by about a half-quart (from 'full' indication on the dipstick), and it now makes the WOT shift. Not sure if the same method will help the part-throttle shift issue. And, as stated all too often on this board, make sure the TV cable is properly adjusted.
Bill
Old Nov 17, 2010 | 05:11 PM
Thanks for the input! I have one last cooler line to fix then I'll try that level method. I'm almost 100% sure my TV cable isn't adjusted properly so I'll make certain to check that out.
Old Nov 19, 2010 | 08:44 PM
Adjusted the TV cable about 5 times. Still doing the same thing. It'll be cheaper for me to just pick up another transmission and call it a day.
junior419
Apr 7, 2025 11:35 AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Night rider327
Sep 2, 2015 04:18 AM
