Went to change my servo, Cover will not free up
Old Nov 20, 2010 | 01:56 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I have a Corvette servo ready to go in my 4L60, in my 91... I have the transmission on the floor, no fluid in it.. I removed the little ring that holds the servo in place, but the cover seems to be jammed in.. Is there a trick I'm missing?
Old Nov 20, 2010 | 02:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Went to change my servo, Cover will not free up
hammer? maybe just stuck, give it a tap and see what happens
Old Nov 20, 2010 | 02:32 PM
vorteciroc's Avatar
Top Answer: 1
The cover is aluminum... do not bang on it with a hammer, the cover will break. Use the handle of a hammer and push the cover in and out (this may take a long time) until you can see the blue o-ring seal that is around the cover. Pull some of the blue o-ring out with a pick and cut it with a pair of dykes. pull the cut o-ring out and use a pair of water pump pliers to remove the cover.
Old Nov 20, 2010 | 03:11 PM
Kevman's Avatar
Engine: 2004 LQ4
I got it out by tapping it with a piece of wood and a hammer, then slowly lifted it, with 2 screwdrivers..
Old Nov 21, 2010 | 01:09 PM
Kevman's Avatar
Engine: 2004 LQ4
Instead of making a new topic..
Where can I get a replacement locking ring for the cover?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
I'llrocya
Feb 2, 2016 11:43 PM
Thornburg
Aug 25, 2015 01:46 AM
