1993 4l60(no E)
Old Nov 12, 2010 | 04:11 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Transmission: TH400 and 6 speed
Axle/Gears: 12 bolt 4.11 and posi 3.73
1993 4l60(no E)
I'm building a TPI setup for my 68 C10 with a new harness and ECU from Larry's Electric. My question is I found a nice clean 4l60 that I would like to use and is there a difference in the harness plugs from 92 to 93 that would keep me from using the 1993 4l60. The harness was built for a 92 setup and a 700r4. Thanks for all replies.
Old Nov 12, 2010 | 07:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1993 4l60(no E)
Since there's no "E", I'd think it would be the same. The 4L60 is supposed to be the same as the 700R4 as far as I know they just changed naming designations in 1993 to prep for the new line of 4L60E, 4L80E, etc.
Old Nov 13, 2010 | 08:29 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 1993 4l60(no E)
Read the TCI instruction link in this recent thread: https://www.thirdgen.org/forums/tran...r4-lockup.html
It covers some detail of the TCC wiring differences for 1993.
Old Nov 14, 2010 | 12:22 AM
Pro Built Automatics's Avatar
Re: 1993 4l60(no E)
If you have the wiring and the wire connector plug from a pre 1993, install it as this will do what you want as far as torque converter lockup. The other plugs that are not used will not effect the TC lockup or anything else.
Old Nov 21, 2010 | 07:39 PM
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Re: 1993 4l60(no E)
Went with a 91 kcase. Found in a Blazer that had already been re-built for 70 dollars out the door at Pull a part.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Linson
Nov 12, 2015 08:09 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Warlocksirix
Sep 3, 2015 12:26 PM
C409
Sep 1, 2015 03:42 PM
