BW 9-bolt pinion nut socket size
Old Nov 23, 2010 | 01:29 PM
mullery's Avatar
Car: 1989 Black IROC-Z
Engine: 305 with G92 option
Transmission: T5 5-speed manual
Axle/Gears: Borg Warner 9-bolt, 3.45 ratio
Does anyone know what size socket is needed for the pinion nut? I have up to 1" and a 1-1/4". It is somewhere in-between.
Thanks!
Old Nov 23, 2010 | 01:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: BW 9-bolt pinion nut socket size
If its anything like the ten bolts, its either a 32 or 33mm, i forget exactly, but maybe that will help.
it is aussie, so it may be metric!
Old Nov 23, 2010 | 01:48 PM
mullery's Avatar
I put an adjustable wrench over it and it looks about 1-1/16" or 27mm. Can anyone confirm that?
Thanks.
Old Nov 23, 2010 | 01:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
if thats so thats much smaller then my ten bolt I just rebuilt.
wow.
sorry I dont have a 9bolt to check for you.
Old Nov 23, 2010 | 02:01 PM
mullery's Avatar
Yeah, I was suprised to see my 1-1/4" socket spin around that smaller nut. Unless someone knows for sure what size I need, I will just pick up a 1-1/16 and a 27mm and just return the one I don't use.
Thanks.
Old Nov 23, 2010 | 02:34 PM
pacamaroman's Avatar
Car: 1983 Camaro Z28
Engine: soon to be an LS1
Transmission: soon to be a T56
Axle/Gears: 9 inch rear 3:70
I just checked my rear and the 27 mm seems to fit better than the 1-1/16.
Old Nov 23, 2010 | 02:36 PM
mullery's Avatar
Awesome, I'll pick up a 27 mm and give it a try.
Thanks!
Fronzizzle
Feb 9, 2017 09:31 AM
dimented24x7
Sep 17, 2015 06:58 AM
6speedIROC
Sep 13, 2015 01:29 PM
Fox118
Sep 12, 2015 09:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
