LT1/T56 cluch master/slave setup...?
Old Nov 24, 2010 | 03:21 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
Hey everyone. I have a 1989 RS Camaro that had 2.8L V6/T5. I am swapping a 95' LT1 & 97 or 98 T56 6 speed manual trans into my car. I am finishing up the list of small parts to complete the swap. I already bought a new clutch slave cylinder. I am just wondering is it possible to use my stock T5 5 speed clutch master cylinder assembly and make it work w/ the LT1 slave cyl setup...? I'm not sure if the LT1 clutch master cylinder is a larger fluid volume or what. Places are telling me the clutch master/slave cylinder setup for LT1's is a complete assembly...but I already have the slave. Just curious what I can or have to do to make my clutch setup work. Any help is greatly appreciated, thanks.
Old Nov 24, 2010 | 10:57 AM
Drew's Avatar
Re: LT1/T56 cluch master/slave setup...?
I had both sitting in front of me and the #1 problem is the hydraulic line on the T5 setup is too short for a T56, but there are other differences too. Just get the T56 setup, it's cheap enough.
Old Nov 24, 2010 | 12:22 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The 98 setup is for an LS and won't work with the LT1. You can get a complete hydraulic assembly from GM for pretty cheap that will work with the LT1. I know you said you already have the slave but you will risk the chance of damaging something by trying to swap parts.
Old Nov 24, 2010 | 02:27 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
McLeod racing offers all the pieces you need including whatever length line you require since the make to length. www.mcleodracing.com
laiky
Mar 20, 2005 12:31 AM
bluepastu
Apr 15, 2003 11:37 AM
RICH92RS350
Mar 18, 2003 05:40 PM
arec2001
Feb 2, 2002 09:34 PM
j166a99
Car Audio
Nov 25, 2001 03:09 AM
