700R4 Question...
Old Nov 24, 2010 | 04:07 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
700R4 Question...
If I leave my car in drive, and floor it, the trans shifts into second gear right away, as the tires are spinning so hard. (With slicks this would be ideal)The car then bogs a bit because it shifted to soon...If on the other hand I manually shift the car it will not shift untill around 7000 RPM, you actually have to let off the gas a bit it seems.....I have adjusted the TV Cable till im blue in the face.....Any ideas??? Could it be the shift governor is messed up..?? Just had it rebuilt not to long ago, the shift is fine, and firm...Band M shift kit, Corvette Servo, 2500 Stall, and Mega Shifter....Thanks for any help on this...
Old Nov 28, 2010 | 01:23 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: 700R4 Question...
You might take a look at this:
https://www.thirdgen.org/forums/tran...ms-solved.html
Not sure it's the complete answer, but bet it has something to do with it -- especially the early 1-2 shift. IMO, there's just no way to diagnose 700R4 problems without a pressure gauge, as its proper operation depends upon proper pressures.
PS - Grew up in TC. Small world.
Old Nov 29, 2010 | 07:31 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
84, I think you are right about the gauge..Thanks...
Old Nov 29, 2010 | 10:05 PM
383TBI's Avatar
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
How does it shift at part throttle?The gov is strictly for wot shifting.If part throttle isn t early than look into the gov.
Old Nov 30, 2010 | 05:52 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Shifts fine at part throttle...
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
