Tremec 5 speed 1988 Camaro
Old Nov 30, 2010 | 06:26 PM
camaro6662's Avatar
Car: Camaro's
Helping a freind out here
Installing tremec 5 speed from summit. It came with a 5 speed.
trans sit/leans at a angle, trans at the tail housing on the cross member left almost touches the other side up about a inch difference. Does he need a spacer or adapter. Or worst case he got the wrong model trans
thanks
Old Nov 30, 2010 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tremec 5 speed 1988 Camaro
is this a t5 or a tko?
what bellhousing are you using? a straight up pattern one or the stock 18 or so degree angles pattern bellhousing? If its an aftermarket t5, its not made to work in a 3rd gen becuase of the angled installation. You will need a straight up pattern bellhousing, which you will have a hard time finding with the hydraulic slave mount.
IDK if the tailhousing is removable and can be swapped?
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
