Lost trans crossmember bolt
Car: '91 z28
Axle/Gears: 3:73 gears
Scared the life out of me when it fell out this am. Can someone tell me what size it is? Standard t5 wc with factory crossmember. Thanks!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lost trans crossmember bolt
the bolt to the frame? i believe is 10mm 1.5, about 1.25" or 1.5" long (30-40mm) How did it "scare you"? there are 2 bolts on each side, if 1 fell out you would never notice. If the crossmember fell on the one side, there could be more wrong than just a missing bolt.
look under the car yet?
Car: '91 z28
Not to the frame. The trans mount bolt...goes through the crossmember. Itmade a terrible noise as the transmission hit the body and the bolt rattled down my driveshaft.
Car: 86 Trans Am
ahh that one.
last one i used was 7/16 course thread IIRC, but was for an poly mount, think its the same?
this says otherwise
https://www.thirdgen.org/trannymount
but the measurements they give in the article are the head size of the bolt/nut, not the thread size
stock appears to use a stud and nut, so maybe you just lost the nut?
this says otherwise
Car: '91 z28
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Yes, the original tranny mount bushing is SAE thread and the crossmenber bolts are metric. Find a decent washer to go with your bolt like a thick fender washer.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
i know the exact bolt you're talking about i just swapped my tranny in 91 rs 305 hope you get it taken care of happy thanks giving!
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
