looking to build 700r4
Old Dec 5, 2010 | 02:26 PM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
ok so i have a 91 z28 350 tpi with the 700r4 tranny recntley started slipping. but i have a new 700r4 and was wanting to put a **** kit and b&m tork master converter in it... here are some links
torque converter
http://www.summitracing.com/parts/BMM-70420/
transgo shift kit
http://www.summitracing.com/parts/TRG-700-2-3/
i was just wondering if anyone has used these products if so results? good bad any? just making sure i only have to do this once and be happy with it lol
Old Dec 5, 2010 | 04:27 PM
Pro Built Automatics's Avatar
Re: looking to build 700r4
The problem is that you said it is slipping... What is it doing exactly? Stay away from B&M torque converters. They have the highest failure rate on the market, and TCI is not much better. If the slipping is minor then I have the modified TransGo Shift kits that will give you what you want and need here. Let me know what is happening that way you can make the right decision, and not spend money unnecessarily.
Old Dec 5, 2010 | 08:03 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I've had both the B&M Kit and Dana's (Pro Built Automatics) Modified TransGo Kit.
The B&M Kit provides unnecessary rough shifts for 1/2 and 2/1 due to the solid spacer used to replace the springs. It was cool for about 2 days then I got tired of it barking the tires constantly and snapping my neck. Not to mention it would spin and kick the car sideways in the rain on steep hills for that shift. Might sound neat but it's not when you're already trying to maintain a low profile due to a roll bar installed in the car.
The TransGO Kit shifts very nice once it gets into the throttle. It doesn't snap or anything like the B&M Kit did and it suppose to hold line pressure better. There's a reason why the TransGo Kit is more expensive than the B&M one.
The smaller the converter will have less rotating weight and a higher torque multipler. I used a 9.5" ACT TQ Converter on mine at around 2400 RPM. It worked nicely on the stock 350 TPI.
I'd say give Dana a call he's always been helpful when I've contacted him. The last time it was just to discuss my project of making a lockup switch for my OD gear. I'm also running his older Street/Strip 700-R4 that has seen 6800 RPM shifts without issue.
http://www.700r4l60e.com/
Old Dec 5, 2010 | 09:16 PM
ok well first of all my reverse slips real bad sometimes.. and when i put it into drive it goes 1 then wants to kick into overdrive then it hits second and takes off. or if the weather is real cold my tranny will want to shift up down up down after i get up to about 55 give or take ten... it gets annoying ive heard good things aabout your shift kits.. and im looking into getting one i want something smooth on part throttle and hard and firm when i get on it and a torque converter with a mild stall im thinking 2000? this id my daily driver just want something that is fun and takes and shifts real good but nothing stupid because like i said its my daily driver... i also have a b&m ratchet shifter and it wont stay down in a lower gear by that i mean i cant just drop the shifter down to second or first..?
Old Dec 5, 2010 | 10:31 PM
It sounds like the TV cable is out of adjustment. Make sure that it is tight at WOT. This might or might not fix reverse. If reverse starts to slip when you are driving it, get out of the throttle immediately. The Shift kit that I offer has the large boost valves, and again this might or might not fix reverse.
Old Dec 5, 2010 | 10:35 PM
well the sift kit and torque converter will be going into a new 700r4 that i have in my garage and i will eventually rebuild and maybe sell this one. but after i get the kit and converter installed the tranny is going in (: sucks i wont be able to see the real results due to bad weather lol
Old Dec 13, 2010 | 03:52 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
ok so this may sound stupid to some of you but i like the barking of the tires and the neck snapping so would i want to go with a b&m than for preference? will a b&m burn and tear up my tranny?
Old Dec 13, 2010 | 08:03 PM
Yes, it will tear it up, and you will get tired of the brutal shifts. If you have a girlfriend, and she rides with you, you will get nothing but complaints from her. So why do it.
Old Dec 15, 2010 | 03:33 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I picked up one of Dana's kits and like it. While I installed the 'crisp' shift option, 2nd is a bit harsh for me (barks/breaks loose when it shifts anywhere above 2K). But overall a wonderfull kit. However I feel a governor adjustment is in dire need that may take care of that and other issues.
On a side note, if she complains you can always look for one that likes it. I found one that likes the car because it's loud and makes clothes smell like raw fuel just pulling out of the garage.
junior419
Apr 7, 2025 11:35 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Jorlain
Oct 8, 2015 01:57 AM
89newfun
Sep 16, 2015 09:28 AM
