fretting over t56 thoughts for ls2... help
Old Dec 5, 2010 | 02:33 PM
ChevyRS-305's Avatar
Ok so im wanting to do an ls2 swap. Only thing is im running a stand alone system from accel and im worried that when I buy a t56 out of a gto or 98- 02 camaro that im going to need an ecu for the tranny because my stand alone system wont opperate the t56 electronics; or does the t56 even have electronics, besides the speedo? Im not vary up to date with the lsx engines or transmissions. Also could I just buy an aftermarket t56 from tremec with a bellhousing for my ls2?
Old Dec 5, 2010 | 03:40 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: fretting over t56 thoughts for ls2... help
T56 has no ECM control that's absolutely required. It does assist with the Rev Lockout when the VSS is not 0mph and the CAGS, but neither is required (or desired in the case of CAGS)
Old Dec 5, 2010 | 04:25 PM
What about this slp skip shift eliminator? Will I need it?
Old Dec 5, 2010 | 05:38 PM
85MikeTPI's Avatar
CAGS = Computer Aided Gear Selection, aka "Skip shift"
Old Dec 6, 2010 | 12:34 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
just leave the cags unplugged and the solenoid won't work. they make a resister to plug in so you won't have a check engine light, but shouldn't be an issue since you aren't running obd2
Old Dec 6, 2010 | 12:35 AM
matthufham's Avatar
Car: 90 z28
Transmission: t56
and you'll have to wire the reverse lockout solenoid to your brake pedal or a switch so you can get it in reverse easily, but not accidentally.
Old Dec 6, 2010 | 12:02 PM
That's a good idea.
Bubbajones_ya
Jul 6, 2024 08:32 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
IROCZ1989
Sep 4, 2015 11:54 AM
tonys91rs
Sep 2, 2015 07:07 PM
