Would this be a good posi unit for me?
Old Dec 14, 2010 | 08:12 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
I have a 10 bolt posi 2.73 currently in my 90 T/A. I want to go with a series 3 carrier / posi with 3.42's. I don't track, Only street driving in the summer, But want better get up and goooo out of the rearend!
I seen a Zexel Torsen with 3.42's on ebay in exellent condition. These came on the LT1's i believe from 99 - 02
Anyone want to chime in and give me your opinion on this unit, and if it would be a good addition for me.
Thanks in advance.
Old Dec 14, 2010 | 10:26 PM
big gear head's Avatar
Re: Would this be a good posi unit for me?
That would probably be the cheapest way to go, and at least it's not an Auburn. I would recommend getting a good instalaltion kit before trying to install it.
Old Dec 15, 2010 | 07:08 AM
Rons91Bird's Avatar
Thanks Big Gear Head!
Rons91Bird's Avatar
Is it a true posi unit?
Old Dec 15, 2010 | 10:38 AM
It is a gear type limited slip (posi), not a clutch type like the Eaton Posi. It will spin both tires if it's in good coondition.
Old Dec 15, 2010 | 06:23 PM
Rons91Bird's Avatar
Would it be a good unit , or would a clutch type unit be preferable?
Old Dec 16, 2010 | 09:33 AM
I prefer the clutch type for street/strip use and the gear type for road racing or auto cross. The gear tyep will work for drag racing too, but not as well as the clutch type.
Old Dec 16, 2010 | 09:59 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
In theory, a clutch type is subject to wearing out the clutches or friction cones where the Torsen that was the standard diff. in 99-02 has no friction materials to wear out. (they make Torsens that additional have friction devices too.)
The Torsen should be a better more natural traction device in wet conditions where the clutch type Eaton or Auburn posi units are friction locked by default, act as an open diff around a corner with little "in between."
For what you said - Torsen all the way.
Old Dec 16, 2010 | 04:46 PM
Rons91Bird's Avatar
Thanks for the replies! Dicisions decisions .. So much info, and so many things to think about.
Thanks ...
Ghettobird52
Jul 5, 2024 11:18 PM
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
