Crossmember bolt size
Old Dec 15, 2010 | 07:05 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Hey guys,
I'm installing a UMI 700-R4 trans cross member. As I was removing the factory cross member, all four factory bolts snapped. Guess I'm gonna have to drill them all out.
The UMI cross member did not come with any bolts.
Can anyone tell me what size the trans cross member bolts are?
Old Dec 15, 2010 | 07:28 AM
Re: Crossmember bolt size
Stock size is 10mm x whatever the "std" (not "fine") thread pitch is for that dia (1.5mm I think) x about 40mm long.
Old Dec 15, 2010 | 08:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by The Project
The UMI cross member did not come with any bolts. Can anyone tell me what size the trans cross member bolts are?
M10 x 1.5 x 32. You might check with UMI, because my cross member arrived with new bolts/washers. You may remember the following review:
https://www.thirdgen.org/forums/afte...-t5-cross.html
JamesC
Old Dec 15, 2010 | 01:47 PM
Car: 89 IROC
JamesC
I book marked your review and I have an ES poly trans mount to install as well.
I sent two emails to UMI and heard nothing. I left them a message on their facebook page as well.
Old Dec 15, 2010 | 04:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is this just the crossmember, or a crossmember mounted torque arm? the crossmember mounted torque arm i bought years ago came with 6 bolts and washers.
Old Dec 15, 2010 | 06:01 PM
JamesC's Avatar
Note what the following advert says about new hardware:
http://www.umiperformance.com/catalo...roducts_id=139
JamesC
Old Dec 16, 2010 | 07:01 AM
Car: 89 IROC
It was just the crossmember (part 2221).
JamesC
Mine didn't come with any hardware. As I stated previously, I sent them two emails and heard nothing....kinda disappointing. I have UMI's sfc, panhard rod and wonderbar and never had an issue before this.
Old Dec 16, 2010 | 07:10 AM
JamesC's Avatar
I emailed Ryan directly with questions and he responded immediately.
JamesC
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
Elliswon
Aug 10, 2015 12:33 PM
