Pre-used flywheel bolts ok?
Old 12-17-2010, 01:48 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
When I mounted the used T56 transmission I just used the enclosed flywheel - and pressure plate bolts.
Torqued according to the LT1 instruction manual and used Loctite thread lock.
After that I've been thinking. Should I have used new bolts? A loose flywheel is scary, but on the other hand, if everything is ok, changing the bolts now is a lot of extra work since the transmission is mounted in place.
The motor is a 350 cid L05 rebuilt with carb.
Old 12-17-2010, 02:55 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: Pre-used flywheel bolts ok?
They're not Torque-to-yield and are fine.
Old 12-17-2010, 09:55 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto. Same with PP bolts torqued mine to 30 lbs last night with no issue. Some say 15 lbs + whatever extra turn, ok.
Old 12-17-2010, 12:53 PM
Hotrodder's Avatar
Engine: 350 CSB
Thank you for your answers!
I'm not a Camaro owner, but thirdgen is where I ask my T56 and LO5 motor questions.
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
Stangski09
11-14-2015 01:27 PM
Nick McCardle
09-10-2015 08:36 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: Pre-used flywheel bolts ok?
