Posi swap
Car: '86 Iroc-Z, '98 A4 Quattro
Engine: 5.0 TPI
Posi swap
I plan on swapping out my 2.73 limited slip rear end for a 9 bolt posi with 3.27's. my question is do I need to change the master cylinder or was in the same in all models of the iroc?
Re: Posi swap
Swapping complete rear axles....All you will need is the Proportioning valve and the parking brake cables from the 9-bolt. The master cylinder dose not need to be replaced.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Posi swap
JamesC
Re: Posi swap
2:73 10-bolts in most cases did not have rear disc brake and he will need the Proportioning valve. I know, been there and done that swap.
Re: Posi swap
JamesC
Re: Posi swap
If the change involves a change to or from the cast-iron calipers, to or from ANYTHING else, a new combo valve will be required.
If the change is from drums to PBRs (aluminum), the existing one will work fine.
The key here is not "9-bolt" or "3.27"; it's the calipers, both the new and the old.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
