How to remove and install 9-bolt ring, bearings, and seals using a 12-ton shop press
Old Jan 4, 2011 | 03:30 PM
mullery's Avatar
Car: 1989 Black IROC-Z
Engine: 305 with G92 option
Transmission: T5 5-speed manual
Axle/Gears: Borg Warner 9-bolt, 3.45 ratio
I bought a 12-ton shop press from Harbor Freight to do some pressing of bearings and seals on rears and transmissions. I've figured out how to use it for removing and installing the pinion bearing and carrier bearings on my 9-bolt.
I was wondering if anyone has some tips on how to use my press to remove and install the ring, bearing, and seal on a 9-bolt axle. Searches in the boards seem to show that most people take it to a shop to have them pressed on/off. I'd like to use my own press for this if possible.
Here's a link to the shop press I bought:
http://www.harborfreight.com/12-ton-...ess-33497.html
Thanks in advance!
Matt
Old Jan 4, 2011 | 03:52 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: How to remove and install 9-bolt ring, bearings, and seals using a 12-ton shop pr
SO FAR ALL I KNOW IS TO CUT THE INNER BEARING RETAINER ALMOST TO THE SHAFT AND BREAK IT WITH A CHISEL. IM IN THE MIDDLE OF A FUEL PUMP CHANGE / FORCED REAR END DROP ON A 1988 5.7 IROC-Z SO I FIGURED CHANGE THE SEALS / BEARINGS WHILE I HAD THE REAR END DROPPED. I HAVE A BW 9 BOLT 7.750" 2.77. IM NOT SURE HOW TO INSTALL THE INNER RETAINER. SEEMS LIKE A JACK HANDLE SLIPPED OVER THE AXLE COULD INSTALL THE INNER RETAINER UNDER A PRESS. I HAVENT TRIED IT YET. THE PRESS I HAVE DOESNT HAVE THE HEIGHT TO DO IT. MITE TRY MACHINE SHOP.
Old Jan 4, 2011 | 05:25 PM
big gear head's Avatar
Do you have one of these? You will need it for pressing the bearings off.
It will be similar to pressing the pinion bearing off.
Old Jan 5, 2011 | 11:25 AM
mullery's Avatar
Yep, I've got a large bearing separator. I think my problem is going to be the length of the axle and fitting it into my 12-ton press. I guess if it doesn't fit, I'll have to take the axles to a machine shop.
BTW Big Gear Head, I've read several of your posts and they have really helped me out. Thanks!
Old Jan 5, 2011 | 12:33 PM
Glad to help.
Old Jan 5, 2011 | 03:36 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Depends on axle length. I know I havent found an axle yet that will fit in my 12 ton HF press. It just is not tall enough.
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
rsrmoore
Aug 7, 2015 08:44 PM
