Rear axle swap
Old Jan 10, 2011 | 11:47 AM
Murraydpsr90's Avatar
Car: 1990 camaro rs
Engine: 5.0
Rear axle swap
I have a 1990 chevy camaro rs. Will a rear axle from a 1985 z28 posi disc fit? Do I need an adjustable proportioning valve? And do I need to change anything about the brakes
Old Jan 10, 2011 | 11:54 AM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
Yes. No. No.
All these could have been answered by looking & reading on TGO. Axle swaps are nothing new here.
Old Jan 10, 2011 | 12:00 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Thanks how do I calibrate the tach and speedo if they are off from the change
Old Jan 10, 2011 | 12:12 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
I did the search for you....
https://www.thirdgen.org/forums/sear...archid=3572930
Old Jan 10, 2011 | 12:18 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
I just read that for the best brake performance I should change the p valve I'm not questioning your knowledge just want to make sure it all works
Old Jan 10, 2011 | 12:21 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
You will find people with opinions going both ways.
Technically for the "best" performance? You probably should. But I know many people who have swapped from drums to discs & experienced no problems.
Old Jan 10, 2011 | 12:23 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Ok sorry to keep bugging you but does it matter if the brakes r forward facing
Old Jan 10, 2011 | 12:28 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
You mean with the calipers mounted to the front of the rotor? I don't think I've seen a 3rd or 4th gen rear end that way.
Old Jan 10, 2011 | 12:32 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
From the pics of it it looks that way. I'll check. Oh how do calibrate the tach and speedo if they are off after the swap
Old Jan 10, 2011 | 12:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear axle swap
The driver's side will be clocked toward the rear, the pass side the front. More info about master, combination valve, speedo gears and parking brake cables can be found in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Tach won't matter. For speedo gears (T5 and 700R4), check the stickies at the top of the page.
JamesC
Old Jan 10, 2011 | 12:44 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
I see the driver is in the rear and the passenger is front mounted I see that my rotor sizes are different 11.6 90-92 and 10.5 82-86 can I change the rear to match the fronts
Old Jan 10, 2011 | 12:49 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
You've already been given links that contain answers to your questions. Go read.
Old Jan 10, 2011 | 01:04 PM
JamesC's Avatar
Re: Rear axle swap
So that you have 10.5" rotors and iron Delco-Moraine calipers on all four corners?
You could, but the 11.6" rotors and alum PBR's calipers are superior to the Delco's. The best idea would be to swap the PBR's to the 85 rear and eventually upgrade the front to match.
JamesC
Old Jan 10, 2011 | 01:17 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
I'd like the 11.6 rotors and alum pbrs on the rears no sense in down grading. Will I have any issues at a part store asking for them to put on my car with a different rear end
Old Jan 10, 2011 | 01:22 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
I read the speedo gear article to change them confused as hell
Old Jan 10, 2011 | 01:25 PM
JamesC's Avatar
Re: Rear axle swap
The process isn't difficult, but you'll have to remove the axles. Here's info that you'll need:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Jan 10, 2011 | 01:51 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
So I just need get p/n 164345/164346 for the calipers and brake pad will I neeed new back plates and does advance have them
Old Jan 10, 2011 | 02:02 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
I see gm has 10 bolt back plates and I see where to order new lines will all these part numbers be the same
Old Jan 10, 2011 | 02:25 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Alright then final thought so if I order all the parts from your Notes then I should have no problems with the setup. And what did I need to remove the axles for
Old Jan 10, 2011 | 03:20 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear axle swap
If you put the bigger brakes on the older rear end & you'll still have the smaller axles. 26 vs 28 spline.
And it is way easier just to swap the whole rear end, than it is to swap brakes onto it.
Old Jan 10, 2011 | 03:57 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Well I don't have to but I've been looking for a rear for mycamaro for awhile andits Ben tough I gues I could look for a 90-92
Old Jan 10, 2011 | 04:03 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Since I have been having trouble finding one it might just be easier for me to get this axle and put the 28's on it and put the new calipers pads, back plates and lines
Old Jan 10, 2011 | 04:12 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
You no I'm just going to look for a newer one with the 11.6's and alum pbrs on it and just clean it up no sense in making more work for myself by removing the axles thanks for the help.
Old Jan 10, 2011 | 06:29 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: Rear axle swap
it should be prity much straght forward to do it seems
Old Jan 10, 2011 | 06:34 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Yeah but if I can get an 89-92 then I won't have to change the axles or anything else unless they are bad. I may just have to change the seals and fluid I'll keep looking I'm waiting on a reply from someone who has an 89 with 411 gears
Old Dec 8, 2011 | 07:32 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Rear axle swap
JamesC
JamesC, i will be doing a rear swap this weekend. However, i don't have a lot of metric tools. I can borrow whatever i need tho. Can you fill me in on what size metric sockets i need besides a 19mm?
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
