truck 4l60e problems
Old Jan 12, 2011 | 11:52 AM
Mrjohnson42087's Avatar
Car: 91 Camaro RS
Engine: LS6
Axle/Gears: 3.08
Im doing a 5.3 4l60e swap into my 86 firebird and im having trouble finding a tailshaft housing for the ls1 camaro 4l60e with the bolt holes for the torque arm. I got my hands on the complete truck setup and Im tring to make it work. Does anyone know where to find or have the part number to the housing? Also I noticed the the rod where the shifter linkage connects is longer than the ls1 camaro 4l60e and was wondering if this is going to be a problem? thanks
Old Jan 12, 2011 | 01:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: truck 4l60e problems
There are torque arm kits now that bolt to the tunnel and/or the crossmember and not the tranny - that would be easy to get and do.
Old Jan 12, 2011 | 09:54 PM
Car: 91 Camaro RS
Engine: LS6
Axle/Gears: 3.08
Where would I find one of these kits because the only ones I have found are for the 700r and T5
Old Jan 13, 2011 | 11:40 AM
Car: 1992 RS
Engine: Carbed 350
Not sure who sells the tunnel-mounted torque arms, I do have a local friend that has one, I'll ask him. Couldn't you also use a 4l60E torque arm and crossmember? Spohn sells those for $369, includes drive shaft loop as well. http://www.spohn.net/shop/1998-2002-...d-Torque-Arms/
jhawkeye
May 25, 2022 06:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
nuggie
Aug 25, 2015 01:27 PM
tricky1
Aug 23, 2015 01:17 PM
