Aluminum Rear End Housing???
Old Jan 15, 2011 | 09:48 AM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Found this while looking around at Currie:
http://www.currieenterprises.com/ces...E.aspx?id=1567
Apparently, its an all aluminum Ford 9" Housing. Any thoughts? If this really is an all aluminum rearend, I'd highly consider a 9" aluminum rear over a built 10-bolt just for the weight savings alone.
Old Jan 15, 2011 | 11:46 AM
big gear head's Avatar
Re: Aluminum Rear End Housing???
The center casting is aluminum but the axle tubes are steel. These were designed for street rods mostly. Putting one in a 3rd gen would be difficult because there is no place to connect the torque arm.
Old Jan 15, 2011 | 11:56 AM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Bummer. That means big bucks on getting it made to fit then. At least its lighter than the stock rear.
Old Jan 15, 2011 | 11:59 AM
After you get all of the parts inside it would probably not be lighter. 9 inch parts are heavy. A stock 9 inch chunk weighs 84 pounds by it's self.
This one weighed 42 pounds when I finished it, but this can not be used on the street.
Old Jan 15, 2011 | 12:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah it is a very heavy rear end. And it would be overkill unless you were planning on 600 HP/600Ft LBs. engine.
Old Jan 15, 2011 | 02:07 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
You'd think with all the advancements made in the last 10yrs on aluminum that this would be a possibility.
Old Jan 16, 2011 | 01:09 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well it is a possibility. We are just saying the amount of work it'll take. It's not that cost efficient and overkill
Old Jan 16, 2011 | 01:40 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
I understand.
hectre13
Dec 11, 2023 08:14 AM
E Rod
Aug 28, 2015 05:17 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
