tring to decide on rear
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
So i'm lost as for what i'm going to do for a rear. I was pricing the one they have on spohn web site and i cant see spending almost 3 grand on a rear. I do want one that will bolt right in.
if you go to this link it has my engine specs.
https://www.thirdgen.org/forums/tech...dy-season.html
any help or suggestion on what to do or what to get would be great. I was thinking about swaping in a 4th gen rear but how tough are they. I was also debatting on 3.73's or 4.11's dont really care about getting on the high way.
Thanks for any help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tring to decide on rear
4th gen rear is the same strength as a 3rd gen rear. You can get a moser housing and axle package 9" setup for under a grand, and use an inexpensive junkyard 9" center chunk. That the cheapest way to do it.
Or just leave the stock one alone and hope for the best.
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
lol the stock is already making a clunk sound when it goes into secound.
when you say center is that gear's to or do i buy them seperate.
and my other thing is the brakes. i know most of them if not all you cant use stock brakes.
The Moser 12 bolt is about $2220 with the Eaton Posi and 30 spline c clip axles. You can use second gen drum brakes on it, or S10 brakes with the 4 bolt backing plate. You can get a bolt in 9 inch Ford housing and axle package for about $960 and use whatever chunk you want in it. The 9 inch can be shipped by UPS.
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
i was just talking to a guy about my rear and he was saying that after i pay to build mine up with new gears and bearings i could just buy a new one.
is this dirrect fit. and what web site you going by.
Car: 87 GTA
But not all 3rd gen rears are equal. Late 3rd gens are stronger than early ones (28 vs 26 spline axles) and the 98-02 rear differentials are stronger than the 91-97 differentials.
Then there is the 9-bolt. Stronger than the 3rd gen 10-bolt, greater than the late 3rd gens & only marginally weaker than the 98-02 rears. Then there is the benefit of bolt in axle retainer instead of the 10-bolts c-clips for the axles. $150 to convert a 10-bolt from a c-clip to a bolt in axle retainer.
If 98-02 cars (the axles)are getting really good performance bone stock, off the showroom floor.....Just how weak are they? What is the fastest stock axle 98-02 axle LS1 car out there?
Car: 86 Trans Am
Car: 86 Trans Am
or go the 12 bolt route that big gear head suggested, it may cost a little more though, you would have to research it
I don't think the 3rd or 4th gen rear end is going to hold up to a 383 with slicks.
The Moser 12 bolt is the lightest and uses less power. The 9 inch can be built cheaper if you use some used parts, but if you use all new parts the 9 inch will be the most expensive.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Late 89 cars through LT1's (93-97) and LS1's (98+) have 28-spline axles and a 7.625 ring gear. Given that, I'd say their strength is pretty much the same. The LS1's have perhaps a better limited slip and braking system.
JamesC
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
