700r4 rebuild kit
Old Jan 15, 2011 | 11:03 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
700r4 rebuild kit
recently i found an 88 k1500 for sale but the trans is going now i though about buying it, but my question is whats a really good, decent priced rebuild kit for a 700r4, i found a few im just looking at what you all haver used and recommend. i thought that since camaros and the truck have the same trans that there is bound to be some common info between them
Old Jan 17, 2011 | 02:04 AM
Pro Built Automatics's Avatar
Re: 700r4 rebuild kit
Go to https://www.700r4l60e.com/store/home.php?cat=19 This will give you what you want and need here, to do it right the first time.
Old Jan 17, 2011 | 10:30 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
ok so whats the difference between that one and the one listed on summit, besides $300
Old Jan 17, 2011 | 02:23 PM
Do your homework and "look" what is in the kits. Mine are the most complete rebuild kits out there. They come with everything. Plus I add fixes and modifications to the kits, that no one else addresses.
Old Jan 17, 2011 | 02:50 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
that is good to know. i talked to they guy with the truck and he said the oil looked murky so im thinking it might just need a new filter and oil, because i had the same thign happen to the camaro after it sat for 4 years, so im hoping for the best, but if i do need a rebuild kit i know where to go now
Old Jan 18, 2011 | 04:28 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
After just finishing a complete rebuild on my 700r4 with a TCI master rebuild kit, and many many trips to the local tranny shop to replace pieces not present in the kit (stator shaft, sunshell, all but 2 barrings, corvette servo, foward sprag, +alot of the smaller pieces) I will have to say I regret not going with pro built. I have spent probably more in the end, and I had to replace just about everything supplied in their kit. Go with Pro-Built. Seems expensive at first, but it is complete, whereas most others are not. In the long run, it is a much better deal.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tonys91rs
Oct 10, 2015 03:31 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
