leaking trans fluid under the radiator
Old Jan 20, 2011 | 01:31 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
i have a 91 z28 with a l98 and for some reason their is tranny fluid leaking under the radiator, any idea what could it be? i checked the little hose coming from the trans to the radiator and it looks fine
Old Jan 20, 2011 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: leaking trans fluid under the radiator
Leaking transmission cooler line.
Old Jan 27, 2011 | 02:51 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
so it is the cooler line, looks like the little bolt is fine but the other end the one that is attached to the radiator is stripped. can it be recoiled?
Old Jan 27, 2011 | 03:12 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If it is stripped, you will have to replace the radiator. The heat exchanger(of which the female fittings are part) is installed in the radiator tank before assembly to the core. There is no reliable method for repairing these fittings if they are badly damaged. You may want to check them carefully to be sure they are stripped and not just missing the outer 1 or 2 threads. If only 1 or 2 threads are damaged, You may be able to clean up the threads and get them to work.
One other option is to bypass the liquid to liquid OE cooler and install a liquid to air, aftermarket cooler. Be aware though that liquid to air coolers are not as efficient. Most are made to work with the OE liquid to liquid cooler. Therefore, you will want one with a high GVW rating(8,600lbs perhaps?) to replace the OE cooler.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
