700-r4 oil pressure question
Car: 2001 Mazada Protege es
Engine: 2.0L dohc
Transmission: G-15m-r
Axle/Gears: 4.10
Howdy I have done some searching on the forums and have not bein able to come with an answer I am trying to find out stock oil pressure for the 700-r4, so I can check it when I go to swap in place of a burnt out 400. Like wise I have the throttle body and bracket already, and some of the stuff to wire in the lockup. The answer is greatly appreciate.
Engine: 2.0L dohc
Axle/Gears: 4.10
Re: 700-r4 oil pressure question
thanks for the information wierdly enough my transmission is a 1990 4l60 out of pickup
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
i figured the 1990 specs should be fairly universal.
most of the bugs were fixed in the 700r4's by then.
Engine: 2.0L dohc
Axle/Gears: 4.10
so I heard from reading, but I checking the serial code and it's a reman 92 in a 90 truck all good thou be usefull to guidelines once I can get back to my old girl it's parked at the shop I work at right now I'm borrowing a company truck to get parts fortunately they will let me
