can i install the ring and pinion on a 4th gen rear end myself?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
I was wondering how hard it would be too install a new ring and pinion on my 4th gen rear end myself, and what special tools are involved? This axle is out of a 1999 camaro and has the zexel torsen carrier and for some reason only has 3.23 ratio so its gotta go.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: can i install the ring and pinion on a 4th gen rear end myself?
https://www.thirdgen.org/forums/tran...axle-gear.html
JamesC
ok cool ty for the info
I'm using the rear brakes that came with my 2001 rear end because, they seem like better brakes than the '89 Camaro ones. I figure if they worked on the 01 rear end they should also work on an '89 rear end. I'm having to modify the brake mounting flanges to get them to work, however.
Per the discussion in your other thread:
Those are also made by PBR. As far as "better", they're not all that different, except that (1) their parking brake setup is completely different, by using a mini drum brake instead of mechanically operating the caliper; and (2) parts are ALOT easier to come by since they're newer and there were FAR more of them released into the world than the 89-92 version. I'm pretty sure you're right about swapping them onto the 89 rear; you'll have to overcome a few details like parking brake cables, but overall they should go on without too much of a fight.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
