700R4 TV Cable Adjustment
Old Jan 24, 2011 | 12:38 PM
srgould41's Avatar
Edit: Never mind. I have read that it is hard to notice the difference between 3rd and 4th without a locking converter, especially at lower speeds.
I installed a TCI TV cable and am trying to get it adjusted. My 700R4 does not have wiring to lock the TC so I am running a non-locking TC. I installed the TV cable per the instructions. It seems to be at the sweet spot. If I move the slider towards the carb (Rochester quad with proper geometry for th700) then it shifts really high in the RPM, further back lower in the RPM.
I have not driven over 45mph yet as I am shaking out the bugs from a frame up resto. So far I have not gotten a 4th gear shift. It shifts great through third. I would have expected the 4th gear shift to happen above 40 or so, but it hasn't.
So should it not select 4th until I am going faster? I have 4.11 gears and 33" tires, by the way, if that makes a difference. I'll get it on the highway eventually, but I don't want to drive it again until the TV cable is correct.
Thanks for your advice
Steve
Hotrodboba400
Dec 10, 2019 07:07 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
