92 RS Posi Swap
92 RS Posi Swap
Hey everyone I am fairly new here and never played around with rear ends before so I have a few questions. Iv tried searching it but couldnt get a straight answer.
I have a 92 rs open rear drum.
I found a 373 posi disk brake rear from a 89 firebird with 88k on it all for $250. From what I understand they do fit in a 92 rs. But what I am not sure is would have to change anything with my transmission?
Also how hard is it actually to do with the disc setup, how much is involved?
Thanks in advance
-Joe
Thanks in advance
-Joe
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 RS Posi Swap
Swaps right in - you just need to get the brake line on the driver side connected to the axle at the T-block - given it's 89 - 92, it might not need anything exept doing it - worst case scenerio, you have to cut a brake like with a small pipe-cutter and flare on end with a flare tool - those might cost $20 for both tools.
Car: 1992 RS
Engine: Carbed 350
Re: 92 RS Posi Swap
Some folks swap in the proportioning valve at the master brake cyclinder for one from a car with rear disc, but others leave it alone and say it works fine. Overall, a simple 3 hour driveway swap.
Consider though - since you are dropping the rear axle for the swap, might as well make a day of it, and drop the gas tank and install a new fuel pump if it's never been done - it's time for one, your 1/2 way there anyway. New sway bar end links, sway bar bushings and shocks would complete the deal, and you'd have the rear all wrapped up!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 RS Posi Swap
You'll need to consider the speedo drive and/or driven gears, combination valve (the bias is different between drum and disc) and so on. Check the brake info in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Re: 92 RS Posi Swap
Thanks for the info guys.
James C i def will check on the year before I buy it, the guy prob just made a mistake.
Some people have told me that since the gears are diff then mine it will mess things up with my tranny, is this true? or will everything work out fine without me touching it?
Joe
Joe
Car: 1990 camaro RS
Engine: 305 TBI
Re: 92 RS Posi Swap
itll mess up your spedometer but not the tranny persay, you can swap the gear in the tranny so it will output the right speed but it wont actully hurt the tranny
Re: 92 RS Posi Swap
Depending on the gear ratio of the new rear vs. your current ratio, you may have to swap only the drive gear, but it's possible you'll have to swap both the drive and driven gears in the trans. If the speedo isn't functioning and everything is in place as it should be, your problem probably goes beyond the gears themselves.
JamesC
JamesC
Car: 1988 Trans am
Engine: 358
Re: 92 RS Posi Swap
Where would you be able to pick up speeds gears then after a swap such as that? And not to steal a post but if I were to put a 1le rear from a 89 into my 88 trans, with the appropriate combination valve, I would just pick up a parking break cable for a 89 trans correct?
Re: 92 RS Posi Swap
http://www.transmissioncenter.net/sp...n_______va.htm
You'll need the 1st design 1LE valve.
Correct. You'll need the 1st design parking brake, 1434 mm.
JamesC
Re: 92 RS Posi Swap
Sometimes the governor needs to be recalibrated when changing rear end gears. This isn't a big deal. Most of the time it's not improtant. You might notice that the transmission changes gears too soon or too late. If this happens you might want to recalibrate it.
Re: 92 RS Posi Swap
I've never heard of this issue before.
JamesC
Re: 92 RS Posi Swap
The governor runs off of the main shaft in the transmission. When you change the gear ratio in the rear end the shaft speed changes for whatever MPH you are running. Sometimes changing the gear in the rear end will cause the transmission to change gears at the wrong time. It's usually not a problem, but sometimes a huge change in the gear ratio will cause the transmission to shift too soon or too late. It's usually only noticable at WOT.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
