my 85 z28 trannys is shot help!!!
Car: 85 z28 iroc
Engine: 305 tpi h.o
what other car's can i swap transmission with if i can't find one out of a 85 and up 700r4 v8 camaro with out to much trouble please anyone help
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: my 85 z28 trannys is shot help!!!
700r4 tranny in my car is out of an '85 chevy caprice
-i just swapped the caprice tail housing for one off a
3rd gen 700r4,4 bolts.
most '82 -93 passenger car 700r4s probably would work
by switching the tail housing for an f-bod one.
you could also fix (or have fixed) your original tranny
BTW what is your tranny doing/why do you think it is
"shot"
"shot"
Car: 85 z28 iroc
Engine: 305 tpi h.o
"shot"
"shot"
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
If you can try to get a 87 up 700r-4 tranny
Car: 85 z28 iroc
Engine: 305 tpi h.o
Car: '82 z28
Engine: L83 5.7
I got my '85 caprice 700r4 in 1995 for $150"as is"
still going strong,so that was a good buy
if you do get a tranny from a car other than a camaro,
some of the"programming"-shift points,shift firmness
speedo gears are likely to be different and may need
tweaked to suit your preferences.When i got the tranny
out of the caprice,i put it on an engine stand and stuck
a transgo shift kit in it before swapping it into the z28.
700r4 tranny got some upgrades in 1984 and further
upgrades in 1987
upgrades in 1987
