700R4 Tranny Fluid
Old Feb 3, 2011 | 11:42 AM
jwoodworth90's Avatar
700R4 Tranny Fluid
Does anyone know what the Tranny Fluid GM specs are for an 85 700R4?
Old Feb 3, 2011 | 12:31 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: 700R4 Tranny Fluid
If you mean how much you need to put in it:
"Pan removal 10pints
Overhaul 23pints"
I have the official 85 manual so if you need some other bit of info be more specific and I'll look it up.
Old Feb 3, 2011 | 10:25 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
At the time, the recommended fluid was Dexron III.
Old Feb 4, 2011 | 11:36 AM
that was the info that i needed. They quit making this though right?
Old Feb 4, 2011 | 01:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
You can still find it.
What happened was that oil companies that offered Dexron III didn't get their license to label their it Dexron III formulation renewed (or whatever) from GM.
Dexron VI is backward compatible, but you can still find Dexron III (unlicensed) most anywhere. I use either Pennzoil or Super Tech brand.
http://www.gm.com/experience/technol...ase_30NO07.doc
In the above document from GM, they state that you should avoid any unlicenced Dexron III. I have used ATF that reads, “suitable for use in DEXRON®-III applications” with no issues. YMMV
Old Feb 4, 2011 | 01:10 PM
Don't worry about it.
Dexron, current version, is what you need. They're backwards-compatible.
Old Feb 4, 2011 | 08:57 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah its just 7 dollars a quart for DEX VI. They still sell DexIII at all auto parts store. Most times it just says Automatic transmission fluid. I know O'reilly's here carries it in Valvoline and O'reilly brand.
Old Feb 4, 2011 | 09:56 PM
Thanks for all the help guys.
srgould41
Jan 9, 2011 02:32 PM
S10GUY
Feb 9, 2009 12:27 AM
StealthElephant
Sep 10, 2003 05:49 PM
SHAGME
Apr 14, 2003 07:34 PM
SHAGME
Apr 12, 2003 10:45 PM
