which torque converter with this cam
Car: 84 z28
Engine: 305 HO
Transmission: 5 spd
Axle/Gears: 3:73 posi
i got a 91 camaro 3.1 that i'm doing an engine swap in. i recently purchased a 350 w/ comp cams thumpr. it will be carbd (holley 750) w/ out a computer. i have a 700r4 out of a 91 z28 w/ stock converter. the cam is:
http://www.compcams.com/Company/CC/c...?csid=107&sb=2
it says "stock converter ok, best with 2000+ converter".
i'm wondering if it would be worth buying a different converter or if it would be fine to just use the stock converter.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: which torque converter with this cam
Link is no good so we have no idea exactly what cam you're talking about.
When the cam companies give a stall speed recommendation, they're very close to what you need. Since they say it will work with a stock converter then you can use your stock converter however you will be giving up some performance by not switching to a high stall converter suited for the camshaft. The higher stall speed gets the engine rpms up quicker into the cams powerband where it will make better power.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
1998 S10 2wd 4.3L stock torque converter will stall around 2200 for you and still be cheap and retain lockup. Autozone, etc will sell them.
Engine: gone
Transmission: gone
Axle/Gears: gone
yup but if your after maximum performance you'd wanna go with a precision industries vigilante converter available with 2400 rpm stall, or edge converters.
Car: 84 z28
Engine: 305 HO
Transmission: 5 spd
sorry.. the link is http://www.compcams.com/Company/CC/c...?csid=107&sb=2
i've read on here about the s10 converters. i think i'll go that route. atleast for now until i get a better trans.
