Rear Diff Oil Fill Plug Stripped
Old Feb 13, 2011 | 06:52 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
So you know that little plug on the side of the rear diff where you add oil. Well mine's stripped. The square indentation where your supposed to put a socket in is round. Anyone else have this problem and if so how did you fix it?
Alex
Old Feb 13, 2011 | 06:56 PM
toomany's Avatar
Re: Rear Diff Oil Fill Plug Stripped
You could try welding a bolt to it. Find one that fits into the stripped out area. I'd try that before I tried drilling and using an easyout. Metal shavings in the rear end would not be a good thing. Or you could get an aftermarket cover that has a drain and fill plug in it.
Old Feb 13, 2011 | 07:23 PM
Drill it out to about 3/8" or larger, then use one of those square bolt extractors. A big one. Replace it with a brass one.
Old Feb 13, 2011 | 07:51 PM
big gear head's Avatar
Stick a bolt in the hole and weld it. The heat will loosen it and you can use a wrench to remove it.
Old Feb 14, 2011 | 06:43 AM
Thanks guys, I don't why the hell I didn't think of welding a bolt to it. What would I do without ya'll But would someone be so kind as to point me in the direction of a replacement plug? rockauto doesn't have them and neither do my local parts stores.
Thanks again
Alex
Old Feb 14, 2011 | 12:09 PM
It's just a standard pipe plug. You can get one at any hardware store.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
draco
Oct 4, 2015 09:25 PM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
