700R4 slipping or out of adjustment?
Old Feb 17, 2011 | 07:55 AM
JVince's Avatar
Car: 89 RS Camaro
Engine: 5.0
Hello,
My wife and I recently purchased an 89 RS automatic that hadn't run in five years. We've got it up and running great but since the first test drive I've noticed some transmission oddities. If you give it just a little gas and drive granny style the tranny seems to shift normally. If you hit it a little harder the RPMs spike up to the 4-5k range (without significant acceleration) and it doesn't seem to want to shift unless you let off the gas. I don't know anything about auto trans but that sounded like slippage to me. What's strange is that it seems to be happening less as we've driven the car around a little more. Last night on a drive around the block I hit it semi-hard and I got good grab and acceleration. Is it possible that the clutch was just gunked up and is now grabbing a little better?
I've also read that the TV or throttle cable could be out of adjustment. The adjustment procedure seems pretty straight forward so maybe I'll try that as well. Opinions?
Old Feb 17, 2011 | 08:21 AM
toomany's Avatar
Re: 700R4 slipping or out of adjustment?
You can try adjusting the TV cable, but it sounds like your trans is on its way out. It is possible that the clutches and passages in the trans were gummed up, but not likely with the symptoms you are describing. How does the fluid look? Does it smell burned?
Old Feb 17, 2011 | 08:31 AM
JVince's Avatar
Car: 89 RS Camaro
Engine: 5.0
The fluid looked OK when I checked it a few weeks back before we got the motor running. I'll give it a good check again today since it's been driven often now. I think we're going to bring it to a tranny shop for a good flush. I'm thinking that combined with the adjustment should pretty much let us know where we stand.
Old Feb 17, 2011 | 08:49 AM
JVince's Avatar
Car: 89 RS Camaro
Engine: 5.0
Also FYI, I think the TCC connector under the dash is unplugged. I found a two prong hanging wire many weeks ago and a few people suspected that's what it is. Could that cause any of these symptoms?
Old Mar 7, 2011 | 03:34 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
The TCC Connector runs directly from the transmission towards the front of the car by the firewall. There is no connector under the dash for the tcc
Old Mar 18, 2011 | 10:14 AM
86z28luv's Avatar
Car: 1986 Camaro z28
So I am having the same issue with my 86 z28. I got it running after it sat for 15 years untouched. Performance Prep/Dr. Injector Mechanics are telling me there is nothing serious wrong with my tranny... they believe its a spring that is getting jammed and then releasing.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
HikoriYami
Sep 21, 2015 07:11 PM
camaronils
Sep 20, 2015 02:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
