differences between third gen axles...
Old Feb 19, 2011 | 05:58 PM
rwhittmore86's Avatar
Want a title? Post!
Car: 92 RS Camaro
Engine: 305 L03
Transmission: 5 speed
Axle/Gears: 3.08
Hey guys i just had a quick question regarding axle shafts in third gens. I have an 86 and a 92 camaro, the 92 is my daily driver at the moment and it has bent axles. I went online to http://www.superioraxlegear.com to see if the shafts out of the two cars had the same part number so maybe i could just swap the axles between the two. Well it has a different part number for the 90 to 92 and says its a 7.625 inch rear with 28 spline axles... is this correct? i wasnt aware there was a difference other than the 9 bolt rear. Thanks ahead of time
Old Feb 19, 2011 | 06:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: differences between third gen axles...
Yes - later years had 28 spline axles and earlier years had 26 spline axles.
Old Feb 19, 2011 | 07:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. BTW, a search will often furnish the info you seek as there's not much that hasn't been asked and answered on site.
Drum and disc axle flanges are also problematic. Check the following link for much more info on the subject to axles:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 19, 2011 | 09:19 PM
Want a title? Post!
Car: 92 RS Camaro
Engine: 305 L03
Axle/Gears: 3.08
awesome thanks for the help guys
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
