rear end swap
Car: 87 Iroc Camaro
Engine: 5.0
rear end swap
ok so a friend of mine has a used rear end out of a 91 firebird i believe with 28 spline axles and the 342 gears and is offering to sell it to me for 150 bucks, is it worth the time and money to swap into my car? i currently have a stock rear end in my 87 lb9 and i planned on wanting to upgrade the gears and was wondering if i should just go this route instead? and from wut ive read most prefer a 342 gear instead of a 373 correct me if im wrong?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: rear end swap
Depending on your intensions the 3.42 is a great compromise in overall performance if you don't mind the little extra rpm at speed 3.73s are great... its in the neighborhood of 200-250 rpm difference between the two. My vote is 3.73
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end swap
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
